DARE!! Instruments RadiLink (100 kOhm)
The DARE!! Instruments RadiLink (100 kOhm) device driver is a Cable which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the DARE!! Instruments RadiLink (100 kOhm):
The frequency range of the DARE!! Instruments RadiLink (100 kOhm) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the DARE!! Instruments RadiLink (100 kOhm).
Be careful changing these settings as RadiMation® is no longer able to verify if the DARE!! Instruments RadiLink (100 kOhm) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: DARE!! Instruments RadiLink (100 kOhm)
- Google image search: DARE!! Instruments RadiLink (100 kOhm)
