DARE!! Instruments RadiMate Coupler
The DARE!! Instruments RadiMate Coupler device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the DARE!! Instruments RadiMate Coupler:
The frequency range of the DARE!! Instruments RadiMate Coupler as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the DARE!! Instruments RadiMate Coupler.
Be careful changing these settings as RadiMation® is no longer able to verify if the DARE!! Instruments RadiMate Coupler is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
