Delphi AR 750HB
The Delphi AR 750HB device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Delphi AR 750HB:
The frequency range of the Delphi AR 750HB as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Delphi AR 750HB.
Be careful changing these settings as RadiMation® is no longer able to verify if the Delphi AR 750HB is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
