DeviceDriverAdvancedAntennaTowerTab
The following settings can be changed for the advanced antenna tower drivers
| Indicate that height changes must be ignored. |
| Indicate that polarization changes must be ignored. |
| Indicate that the antenna height must be changed before the test is started. |
| The position to which the antenna tower must be moved before the test is started. |
| Indicate that the antenna height must be changed after the test is finished. |
| The position to which the antenna tower must be moved after the test is finished. |
| The time that must be wait when changing the polarisation. |
