DeviceDriverFirmwareUpdateTab
Note: This page is used to show the firmware update configuration of the Raditeq device drivers. This page can now easily be embedded on all relevant device driver pages.
The Firmware update tab can be used to update the firmware of the DeviceDriverFirmwareUpdateTab.
Warning: The firmware update can take a few minutes. During the actual firmware update the window is disabled, and cannot be closed. It is possible that Microsoft Windows shows messages that the RadiMation® software is not responding. Ignore those messages and do not kill, abort or end the software. Also do not disconnect the connection between the DeviceDriverFirmwareUpdateTab and the PC, while the firmware update is being performed.
