DeviceDriverFrequencyRangeTab
The frequency range of the DeviceDriverFrequencyRangeTab as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the DeviceDriverFrequencyRangeTab.
Be careful changing these setting as RadiMation® is no longer able to verify if the DeviceDriverFrequencyRangeTab is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
