DeviceDriverGenericConfigurationCalibrationJig
The following tabs are available in the advanced configuration of the DeviceDriverGenericConfigurationCalibrationJig:
The frequency range of the DeviceDriverGenericConfigurationCalibrationJig as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the DeviceDriverGenericConfigurationCalibrationJig.
Be careful changing these setting as RadiMation® is no longer able to verify if the DeviceDriverGenericConfigurationCalibrationJig is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
