DeviceDriverGenericConfigurationPreAmplifier
Note: This page is used to show the configuration that is generic for all preamplifier device drivers. This page will automatically be embedded on all preamplifier device driver pages.
The following tabs are available in the advanced configuration of the DeviceDriverGenericConfigurationPreAmplifier:
The frequency range of the DeviceDriverGenericConfigurationPreAmplifier as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the DeviceDriverGenericConfigurationPreAmplifier.
Be careful changing these settings as RadiMation® is no longer able to verify if the DeviceDriverGenericConfigurationPreAmplifier is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
