DeviceDriverGenericConfigurationResistor
The following tabs are available in the advanced configuration of the DeviceDriverGenericConfigurationResistor:
The frequency range of the DeviceDriverGenericConfigurationResistor as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the DeviceDriverGenericConfigurationResistor.
Be careful changing these setting as RadiMation® is no longer able to verify if the DeviceDriverGenericConfigurationResistor is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
