DeviceDriverRadiSenseUserCorrectionTab
The User Correction tab can be used to upload the data of an user correction into the DeviceDriverRadiSenseUserCorrectionTab. This correction data can be used by the probe internally to to correct the measured values.
| If this option is activated, and if a user correction is stored in the probe, then the correction will be used by the probe itself, to internally correct the measured value with the user calibration data. If this option is off, no correction of the measured values will be done. |
| Allows to select the correction file that contains the user correction data of the DeviceDriverRadiSenseUserCorrectionTab. |
| Starts the actual uploading of the correction table. First some checks are performed, and if those checks are successful, the actual uploading is performed. |
| Downloads the user correction table from the probe, if available. Then displays a 'Save As' prompt to save the table as a RadiMation correction file. |
