Device Types
A/D converter
The A/D convertor is used to monitor the EUT during testing. All supported A/D converter devices can be found here
Absorbing Clamp
The absorbing clamp is used measure the conducted emission All absorbing clamp devices can be found here
Amplifier
The amplifier is used to generate power for immunity tests All supported amplifier devices can be found here
Antenna
The antenna is used to send or receive signals All supported antenna devices can be found here
Antenna Tower
The antenna tower is used to move the antenna in height and change the polarisation All supported antenna tower devices can be found here
Cable
The cable is used to enable signals paths to be better defined. You do not need to insert a cable, but especially for emissions it does give you a more accurate result. All supported cable devices can be found here
Calibration Antenna
The calibration antenna is used magnetic field calibration. All supported calibration antenna devices can be found here
Positioner
The positioner is used to position a positioner for the measurements All positioners devices can be found here
Coupler
The coupler is used for coupling the power meter to be measured power. All supported coupler devices can be found here
Current Sensor
The current sensor is used for measuring the current in a cable. All supported current sensor devices can be found here
EFT Burst Generator
The EFT burst generator is used for recording the used generator. All supported EFT burst generator devices can be found here
ESD Generator
The ESD generator is used for recording the used generator. All supported ESD generator devices can be found here
EUT Controller
The EUT controller is used for controlling the EUT during immunity measurements All supported EUT controller devices can be found here
Field Sensor
The field sensor is used for measuring the field generated during a radiated immunity measurement. All supported field sensor devices can be found here
Forward Power Meter
The forward power meter is used for measuring the forward power during an immunity measurement. All supported forward power meter devices can be found here
Injection Device
The injection device is used for injecting the power into cables. All supported injection devices can be found here
Jig
The Jig is used for calibrating the injection devices. All supported Jig devices can be found here
LISN
The LISN is used for measuring conducted emissions All supported LISN devices can be found here
Modulation Source
The modulation source is used as an external modulator for the signal generator. All supported modulation source devices can be found here
Multimeter
The multimeter is used to monitor voltage over a coil during MIL STD testing. All supported multimeter devices can be found here
Network Analyser
The network analyser is used for specialized calibration tests. All supported network analyser devices can be found here
Oscilloscope
The oscilloscope is used to monitor voltage over a coil during MIL STD testing. All supported oscilloscope devices can be found here
Output Coupler
The output coupler is used for coupling the output power meter to be measured power, used in a strip line set up. All supported output coupler devices can be found here
Output Power Meter
The Output power meter is used for measuring the output power during an immunity measurement, used in a strip line set up. All supported output power meter devices can be found here
Pre Amplifier
The pre amplifier is used to amplify the incoming signals. All supported amplifier devices can be found here
Reflected Power Meter
The reflected power meter is used for measuring the reflected power during an immunity measurement. All supported forward power meter devices can be found here
Resistor
The resistor is used to monitor voltage over a coil during MIL STD testing. All supported resistor can be found here
Sensor Power Meter
The sensor power meter is used for measuring the power at the current sensor during an immunity measurement. All supported sensor power meter devices can be found here
Signal Generator
The signal generator is used to generate power for immunity tests. All supported signal generator devices can be found here
Spectrum Analyser
The spectrum analyser is used to receive the emission coming from the EUT. All supported spectrum analyser devices can be found here
Surge Generator
The surge generator is used for recording the used generator. All supported surge generator devices can be found here
Switch matrix
The switch matrix is used to create the signal path of the emitted or received signal All supported switch matrix devices can be found here
Turn Table
The Turn Table is used to turn the EUT in the correct position. All supported turn table devices can be found here
