EATON 95241-1
The EATON 95241-1 device driver is a Calibration Jig which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the EATON 95241-1:
The frequency range of the EATON 95241-1 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the EATON 95241-1.
Be careful changing these setting as RadiMation® is no longer able to verify if the EATON 95241-1 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: EATON 95241-1
- Google image search: EATON 95241-1
