EMCO 3102
The EMCO 3102 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the EMCO 3102:
The frequency range of the EMCO 3102 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the EMCO 3102.
Be careful changing these settings as RadiMation® is no longer able to verify if the EMCO 3102 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
