EMCO 3145DP
The EMCO 3145DP device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the EMCO 3145DP:
The frequency range of the EMCO 3145DP as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the EMCO 3145DP.
Be careful changing these settings as RadiMation® is no longer able to verify if the EMCO 3145DP is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: EMCO 3145DP
- Google image search: EMCO 3145DP
