EMCO 3160-01
The EMCO 3160-01 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the EMCO 3160-01:
The frequency range of the EMCO 3160-01 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the EMCO 3160-01.
Be careful changing these settings as RadiMation® is no longer able to verify if the EMCO 3160-01 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: EMCO 3160-01
- Google image search: EMCO 3160-01
