EMC Baden GTEM-Cell 3750
The EMC Baden GTEM-Cell 3750 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the EMC Baden GTEM-Cell 3750:
The frequency range of the EMC Baden GTEM-Cell 3750 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the EMC Baden GTEM-Cell 3750.
Be careful changing these settings as RadiMation® is no longer able to verify if the EMC Baden GTEM-Cell 3750 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: EMC Baden GTEM-Cell 3750
- Google image search: EMC Baden GTEM-Cell 3750
