EMC Shop DC1G-1000A
The EMC Shop DC1G-1000A device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the EMC Shop DC1G-1000A:
The frequency range of the EMC Shop DC1G-1000A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the EMC Shop DC1G-1000A.
Be careful changing these settings as RadiMation® is no longer able to verify if the EMC Shop DC1G-1000A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: EMC Shop DC1G-1000A
- Google image search: EMC Shop DC1G-1000A
