EM Systems A6100
The EM Systems A6100 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the EM Systems A6100:
The frequency range of the EM Systems A6100 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the EM Systems A6100.
Be careful changing these settings as RadiMation® is no longer able to verify if the EM Systems A6100 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: EM Systems A6100
- Google image search: EM Systems A6100
