ENI 310L
The ENI 310L device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ENI 310L:
The frequency range of the ENI 310L as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the ENI 310L.
Be careful changing these settings as RadiMation® is no longer able to verify if the ENI 310L is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
