ENI A-300
The ENI A-300 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ENI A-300:
The frequency range of the ENI A-300 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the ENI A-300.
Be careful changing these settings as RadiMation® is no longer able to verify if the ENI A-300 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
