ETM 200 LS (ZAMM)
The ETM 200 LS (ZAMM) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ETM 200 LS (ZAMM):
The frequency range of the ETM 200 LS (ZAMM) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the ETM 200 LS (ZAMM).
Be careful changing these settings as RadiMation® is no longer able to verify if the ETM 200 LS (ZAMM) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
