ETS-Lindgren 3106B
The ETS-Lindgren 3106B device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ETS-Lindgren 3106B:
The frequency range of the ETS-Lindgren 3106B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the ETS-Lindgren 3106B.
Be careful changing these settings as RadiMation® is no longer able to verify if the ETS-Lindgren 3106B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: ETS-Lindgren 3106B
- Google image search: ETS-Lindgren 3106B
