ETS-Lindgren 3112
The ETS-Lindgren 3112 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ETS-Lindgren 3112:
The frequency range of the ETS-Lindgren 3112 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the ETS-Lindgren 3112.
Be careful changing these settings as RadiMation® is no longer able to verify if the ETS-Lindgren 3112 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: ETS-Lindgren 3112
- Google image search: ETS-Lindgren 3112
