ETS-Lindgren 3117 with Pre-amp
The ETS-Lindgren 3117 with Pre-amp device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ETS-Lindgren 3117 with Pre-amp:
The frequency range of the ETS-Lindgren 3117 with Pre-amp as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the ETS-Lindgren 3117 with Pre-amp.
Be careful changing these settings as RadiMation® is no longer able to verify if the ETS-Lindgren 3117 with Pre-amp is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: ETS-Lindgren 3117 with Pre-amp
- Google image search: ETS-Lindgren 3117 with Pre-amp
