ETS-Lindgren 3142E
The ETS-Lindgren 3142E device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ETS-Lindgren 3142E:
The frequency range of the ETS-Lindgren 3142E as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the ETS-Lindgren 3142E.
Be careful changing these settings as RadiMation® is no longer able to verify if the ETS-Lindgren 3142E is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: ETS-Lindgren 3142E
- Google image search: ETS-Lindgren 3142E
