ETS-Lindgren 3145BDP
The ETS-Lindgren 3145BDP device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ETS-Lindgren 3145BDP:
The frequency range of the ETS-Lindgren 3145BDP as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the ETS-Lindgren 3145BDP.
Be careful changing these settings as RadiMation® is no longer able to verify if the ETS-Lindgren 3145BDP is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: ETS-Lindgren 3145BDP
- Google image search: ETS-Lindgren 3145BDP
