ETS-Lindgren EMSwitch 7001-012
The ETS-Lindgren EMSwitch 7001-012 device driver is a Switch Matrix which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ETS-Lindgren EMSwitch 7001-012:
There are several methods in which the ETS-Lindgren EMSwitch 7001-012 can be connected to the PC. The ETS-Lindgren EMSwitch 7001-012 can for example be connected directly to the PC, or through a plugincard in a RadiCentre 1 or a multi-slot RadiCentre. More information on how to use the RadiCentre is present in the product manual of the RadiCentre. The settings on the RadiCentre tab can be used to specify how the ETS-Lindgren EMSwitch 7001-012 is connected.
When the ETS-Lindgren EMSwitch 7001-012 is connected to a multi-slot RadiCentre, also the slot number in which the plugincard is fitted, should be specified.
| Specifies that the ETS-Lindgren EMSwitch 7001-012 is connected directly to the PC, without the use of a RadiCentre. |
| Specifies that the ETS-Lindgren EMSwitch 7001-012 is connected to a plugincard that is fitted in a RadiCentre 1. |
| Specifies that the ETS-Lindgren EMSwitch 7001-012 is connected to a plugincard that is fitted in a multi-slot RadiCentre that also can be manually controlled using the display on the front of the RadiCentre. The slot number in which the plugin card is mounted can also be selected. |
| Specifies that the ETS-Lindgren EMSwitch 7001-012 is connected to a plugincard that is fitted in a multi-slot RadiCentre Ultra. This RadiCentre Ultra has no display, and can only be used when remote controlled. |
The configuration on the Communication tab should be configured depending on the outgoing connection from the PC. Thus if Directly to PC is selected, the communication settings should be configured as what is actually used between the PC and the ETS-Lindgren EMSwitch 7001-012 itself. If RadiCentre 1, RadiCentre multi-slot or RadiCentre multi-slot Ultra is selected, the communication settings should be configured as what is actually used between the PC and the RadiCentre. In the configuration where a RadiPower is connected with USB to a multi-slot RadiCentre, which is connected by GPIB to the PC, the communication settings of the RadiPower device driver should thus be GPIB.
If the ETS-Lindgren EMSwitch 7001-012 is for example connected to slot 3 of a multi-slot RadiCentre which has IP address 192.168.178.95 and is connected by LAN to the PC, the following settings should be configured in the device driver of the ETS-Lindgren EMSwitch 7001-012:
- RadiCentre tab
- Communication tab
- Communication Stream: VISA
- LAN: 192.168.178.95
The Firmware update tab can be used to update the firmware of the ETS-Lindgren EMSwitch 7001-012.
| Specifies the filename of the firmware update file that should be used to update the firmware of the measurement device. |
| Allows to select the firmware update file. |
| Starts the actual firmware update. First some checks are performed, and if those checks are successful, the actual firmware update is performed. |
| Shows a message during the firmware update, indicating the performed action and the actual status. |
| Warning: | The firmware update can take a few minutes. During the actual firmware update the window is disabled, and cannot be closed. It is possible that Microsoft Windows shows messages that the RadiMation® software is not responding. Ignore those messages and do not kill, abort or end the software. Also do not disconnect the connection between the ETS-Lindgren EMSwitch 7001-012 and the PC, while the firmware update is being performed. |
