ETS-Lindgren GTEM-Cell 5317
The ETS-Lindgren GTEM-Cell 5317 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ETS-Lindgren GTEM-Cell 5317:
The frequency range of the ETS-Lindgren GTEM-Cell 5317 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the ETS-Lindgren GTEM-Cell 5317.
Be careful changing these settings as RadiMation® is no longer able to verify if the ETS-Lindgren GTEM-Cell 5317 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: ETS-Lindgren GTEM-Cell 5317
- Google image search: ETS-Lindgren GTEM-Cell 5317
