ETS Lindgren 3142D
The ETS Lindgren 3142D device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ETS Lindgren 3142D:
The frequency range of the ETS Lindgren 3142D as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the ETS Lindgren 3142D.
Be careful changing these settings as RadiMation® is no longer able to verify if the ETS Lindgren 3142D is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: ETS Lindgren 3142D
- Google image search: ETS Lindgren 3142D
