ETS Lindgren GTEM-Cell 5405
The ETS Lindgren GTEM-Cell 5405 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ETS Lindgren GTEM-Cell 5405:
The frequency range of the ETS Lindgren GTEM-Cell 5405 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the ETS Lindgren GTEM-Cell 5405.
Be careful changing these settings as RadiMation® is no longer able to verify if the ETS Lindgren GTEM-Cell 5405 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
