Emission.Multiband.Sequence.AutoMeasurePeaks
This advanced option specifies if the multiband emission test should perform a final measurement of the detected peaks when it is run from a sequence.
The default value of Emission.Multiband.Sequence.AutoMeasurePeaks is set to True, and it will thus also perform a final measurement. If no final measurement on the peaks is needed when the emission test is running from a sequence, this advanced option can be set to False.
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
