Emtest DCD-ST
The emtest DCD-ST device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Emtest DCD-ST:
The frequency range of the Emtest DCD-ST as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Emtest DCD-ST.
Be careful changing these settings as RadiMation® is no longer able to verify if the Emtest DCD-ST is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
