Exodus advanced communications AMP2102DB-5
The Exodus advanced communications AMP2102DB-5 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Exodus advanced communications AMP2102DB-5:
The frequency range of the Exodus advanced communications AMP2102DB-5 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Exodus advanced communications AMP2102DB-5.
Be careful changing these settings as RadiMation® is no longer able to verify if the Exodus advanced communications AMP2102DB-5 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Exodus advanced communications AMP2102DB-5
- Google image search: Exodus advanced communications AMP2102DB-5
