FT RF CESGH-1500-10-NF
The FT RF CESGH-1500-10-NF device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the FT RF CESGH-1500-10-NF:
The frequency range of the FT RF CESGH-1500-10-NF as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the FT RF CESGH-1500-10-NF.
Be careful changing these settings as RadiMation® is no longer able to verify if the FT RF CESGH-1500-10-NF is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: FT RF CESGH-1500-10-NF
- Google image search: FT RF CESGH-1500-10-NF
