FT RF CESGH-650-20-C-NF
The FT RF CESGH-650-20-C-NF device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the FT RF CESGH-650-20-C-NF:
The frequency range of the FT RF CESGH-650-20-C-NF as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the FT RF CESGH-650-20-C-NF.
Be careful changing these settings as RadiMation® is no longer able to verify if the FT RF CESGH-650-20-C-NF is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
