Fischer Custom Communications F-33-1
The Fischer Custom Communications F-33-1 device driver is a Current Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Fischer Custom Communications F-33-1:
The frequency range of the Fischer Custom Communications F-33-1 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Fischer Custom Communications F-33-1.
Be careful changing these settings as RadiMation® is no longer able to verify if the Fischer Custom Communications F-33-1 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Fischer Custom Communications F-33-1
- Google image search: Fischer Custom Communications F-33-1
