Fischer Custom Communications F-65 A
The Fischer Custom Communications F-65 A device driver is a Current Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Fischer Custom Communications F-65 A:
The frequency range of the Fischer Custom Communications F-65 A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Fischer Custom Communications F-65 A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Fischer Custom Communications F-65 A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Fischer Custom Communications F-65 A
- Google image search: Fischer Custom Communications F-65 A
