Fischer Custom Communications FCC-801-M5-100A
The Fischer Custom Communications FCC-801-M5-100A device driver is a Current Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Fischer Custom Communications FCC-801-M5-100A:
The frequency range of the Fischer Custom Communications FCC-801-M5-100A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Fischer Custom Communications FCC-801-M5-100A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Fischer Custom Communications FCC-801-M5-100A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Fischer Custom Communications FCC-801-M5-100A
- Google image search: Fischer Custom Communications FCC-801-M5-100A
