Flann Microwave 08240
The Flann Microwave 08240 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Flann Microwave 08240:
The frequency range of the Flann Microwave 08240 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Flann Microwave 08240.
Be careful changing these settings as RadiMation® is no longer able to verify if the Flann Microwave 08240 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Flann Microwave 08240
- Google image search: Flann Microwave 08240
