Frankonia ALX-8000E
The Frankonia ALX-8000E device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia ALX-8000E:
The frequency range of the Frankonia ALX-8000E as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Frankonia ALX-8000E.
Be careful changing these settings as RadiMation® is no longer able to verify if the Frankonia ALX-8000E is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Frankonia ALX-8000E
- Google image search: Frankonia ALX-8000E
