Frankonia BTA-L
The Frankonia BTA-L device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia BTA-L:
The frequency range of the Frankonia BTA-L as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Frankonia BTA-L.
Be careful changing these settings as RadiMation® is no longer able to verify if the Frankonia BTA-L is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Frankonia BTA-L
- Google image search: Frankonia BTA-L
