The Frankonia EFS-300 device driver is a Field Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia EFS-300:
Pre Wait Time
Wait time before starting the measurement-loop. Can be used to wait for a signal generator, and or amplifier to stabilize.
Measure
The minimum amount of measurements in the measure loop. Continues to loop even if field strength level is stable.
Wait Time
The wait time between each measurement is taken, during the measurement-loop.
Max. Difference
If the measured field strength between each measurement in the measurement-loop, is less than this value. The measured field strength is stable. The measurement-loop will then stop.
Max. Measure
The maximum amount of measure times, for the measurement-loop
Both for the leveling, and the monitoring these settings can be set individually.
The leveling is used, whenever RadiMation® is measuring the field strength, to regulate the signal generator.
If the field sensor is only used as input, without regulating on it, then the monitoring settings are used.
The frequency range of the Frankonia EFS-300 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Frankonia EFS-300.
Use default start frequency
Custom start frequency
Use default stop frequency
Custom stop frequency
Be careful changing these settings as RadiMation® is no longer able to verify if the Frankonia EFS-300 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
