Frankonia FLC-100E
The Frankonia FLC-100E device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia FLC-100E:
The frequency range of the Frankonia FLC-100E as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Frankonia FLC-100E.
Be careful changing these settings as RadiMation® is no longer able to verify if the Frankonia FLC-100E is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
