Frankonia FLG-100F
The Frankonia FLG-100F device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia FLG-100F:
The frequency range of the Frankonia FLG-100F as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Frankonia FLG-100F.
Be careful changing these settings as RadiMation® is no longer able to verify if the Frankonia FLG-100F is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
