Frankonia FLG-50
The Frankonia FLG-50 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia FLG-50:
The frequency range of the Frankonia FLG-50 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Frankonia FLG-50.
Be careful changing these settings as RadiMation® is no longer able to verify if the Frankonia FLG-50 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
