Frankonia FLH-1000B1
The Frankonia FLH-1000B1 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia FLH-1000B1:
The frequency range of the Frankonia FLH-1000B1 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Frankonia FLH-1000B1.
Be careful changing these settings as RadiMation® is no longer able to verify if the Frankonia FLH-1000B1 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
