Frankonia HAX-40
The Frankonia HAX-40 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia HAX-40:
The frequency range of the Frankonia HAX-40 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Frankonia HAX-40.
Be careful changing these settings as RadiMation® is no longer able to verify if the Frankonia HAX-40 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Frankonia HAX-40
- Google image search: Frankonia HAX-40
