Frankonia LOP 180
The Frankonia LOP 180 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia LOP 180:
The frequency range of the Frankonia LOP 180 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Frankonia LOP 180.
Be careful changing these settings as RadiMation® is no longer able to verify if the Frankonia LOP 180 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Frankonia LOP 180
- Google image search: Frankonia LOP 180
