Frankonia TEMpact
The Frankonia TEMpact device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia TEMpact:
The frequency range of the Frankonia TEMpact as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Frankonia TEMpact.
Be careful changing these settings as RadiMation® is no longer able to verify if the Frankonia TEMpact is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Frankonia TEMpact
- Google image search: Frankonia TEMpact
