Frankonia VKO 200
The Frankonia VKO 200 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Frankonia VKO 200:
The frequency range of the Frankonia VKO 200 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Frankonia VKO 200.
Be careful changing these settings as RadiMation® is no longer able to verify if the Frankonia VKO 200 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Frankonia VKO 200
- Google image search: Frankonia VKO 200
